Brief Description: Left Wing Nav Light drill route and test
Drilled left wing nav light wire bundle. Put nylon grommets in place then ran wire through them. Wire is all wax stringed. Printed final heat shrink markers and put on Nav Light wires. Started buildnig connectors for Nav lights. First set I was using incorrect crimp settings but next I got the correct (trial and error). Hooked car battery up on root side of wires and tested strobe and nav pos lights (both). Works!
