LANCE'S WEB SITE
Date:  12-6-2020
Number of Hours:  3.00
Brief Description:  Rear spar debur and prime, also rear rib backplate
Deburring and priming (cortec) rear spar (left wing). Also, desided to drill out rear-rib to main spar rivets, on Rear Rib #8, and put a backplate on it due to a pilot hole that's a we bit off from the actual drill hole. Primed and re-installed. The backplate is on the rear rib front flange and is the same-size as the whole flange spanning all five of the A5 rivets.
