Brief Description: Aileron trim hinge and actuator rod hole.
Final hole drill and Cleco'd the aileron trim and hinge.
Then started work on the actuator rod hole that goes in the channel and skin. I first pilot hole drilled. Then I used the dremel with a CNC type drill bit to outline the hole. Then cleaned up with a rounded vixen file.
