LANCE'S WEB SITE
Date: 4-11-2020
Number of Hours: 10.00
Manual Reference: 6W1
Brief Description: Right Flap: debur, cortec, reassemble, rivet, hing
Took right flap apart and deburred. I then used the still borrowed (thanks Kevin!) airbrush and sprayed the inside of the flap. I then brushed the edges (1" foam brush). Worked great yet again! Airbrush is definately the way to go for me!
Anyhow, after it dried, I reassembled it, re-checked the level on the 12' table bars (12'x2"x1/4"), and cargo strapped that puppy back down. Cleco'd it, and riveted it. Once again had to shorten the flap trailing edge rivets by about 1/3rd.
Had to trim the hinge down just a wee little bit more, pop the hinge pin out to trim it, drilled the hinge end hole, safety wired it, and DONE.
I then built another quick hanger/shelf for the elevators in the floor joists.
READY for the next step! I belive it's the ailerons.
Started the day out right with a strong cup of coffee
Reassembly of Rt Flap. Stand off edge so I can fit the other edge inside
Had same problem with trailing edge flap rivets.
