I worked on the front and rear Spars for the Horizontal Stab tonight. I have the spars complete minus some round file work to do on the rear spar bracket. It took a bit of time to make the bracket and I think that Zenith should complete the part for the Kit. The 0.63 material is pretty thick and cutting it with the hand shears is quite a chore.I had the bracket on up-side down at first, and almost drilled before I noticed the plans showed the top was UP! What a concept!
