The serial comm cables were too long between the Megajolt Jr. ignition control units and the serial ports on the instrument panel. I cut the cables to length and put new connectors on the ends. I also worked on the Dynon Skyview to configure the GRT Hall effect current sensor, but I didn't have the correct instructions to do it. I printed the instructions from the Skyview installation manual to do this tomorrow.
I fabricated a stiffener for the bottom of the fuse block panel and installed it. This will make securing the fuse panel up and out of the way more secure.
Ignition control units serial comm wires shortened to fit.
