Fabricated three brass bus bars for the three EDIS ignition terminal strips. Several wires needed to be terminated together that supply ignition pulses to the three ignition coils on the Ford coil pack. I chose to use terminal strips to accomplish the joining of the wires. This methos allows easy changing of coil wires to change firing order of the coils if needed. The # 2 EDIS ignition has to be wired with the firing order lagging the firing order of the #1 EDIS by 1 position because the #2 EDIS crank position sensor lags the #1 crank position sensor by 120 degrees. I needed to make shorting bus bar connection between the terminals of each terminal strip.
