Louies Web Site
Date:  9-3-2012
Number of Hours:  3.50
Brief Description:  Cooling system
Added two more layers of glass cloth over the top side of the lower cowl air inlet edge extensions. Heated the high temp epoxy to hasten the cure and to heat cure it for high temp durability. After curing, trimmed the extensions and put the lower cowl back on.
Lower cowl air opening extension right side.
Lower cowl air opening extension left side.
