Finished painting aileron balance weights. Determined size of access opening in the bottom of the wing so the balance weights could be installed or removed from the balance arm. The balance weights can not be installed to take the aileron off the wing or put it back on. Cut out the access hole in the bottom skin. Cut out a cover for the hole from 0.025 6061 T6 sheet.
