Brief Description: Valve seats cut, valves ground and installed
After the heads were coated, the next task was to cut the valve seats and grind the valves for perfect seal. The seats were cut to angles of 60, 45, 30, and 15 degrees. The sealing surface is on the 45 degree seat. After the seat angles were cut, the valves were ground in for a proper seal.
