Louies Web Site
Date:  8-23-2014
Number of Hours:  50.00
Brief Description:  Cyl & combustion chamber machining
Machine work on cyl heads to increase counterbore size to accept the VW 92mm barrels. Change combustion chamber size and shape to get compression ratio below 10:1. Cut a groove in the squish area pointing at the spark plug. Reportedly, this groove will squirt the mixture at the plug when it fires and promote rapid mixture buring.
Brady's CNC mill cutting counterbore to fit VW cylinders
Machining head to fit VW cylinders
Initial combustion chamber  machining done
