Louies Web Site
Date:  10-18-2012
Number of Hours:  1.60
Brief Description:  Flow restrictors
Made flow restrictors from 1/4" diameter brass rod to put in the AN fittings at the oil pressure, and fuel regulator vent ports. The flow restrictors were threaded to 1/4"x28 and screwed into the 1/4"x28 tapped inlet side of the fittings. The restrictor holes were drilled with a #55 (0.046") drill bit. The purpose of the restrictors is to limit the flow from the oil pressure sensor line and the fuel vent return line in case the line should break.
Oil pressure and fuel vent line restrictors
Restrictor and AN fittings.
