Fabricating carb heat hot air collector under the number 1 cylinder head. Finished welding a support for the collector to the attaching bracket. Welded aluminum sheet to close up the end of the collector. Riveted the collector to the support bracket. Trial installed the hot air collector to the #1 cylinder exhaust pipe.
Next, a 2" diameter outlet needs to be fabricated and welded to the bottom of the air box.
