Louies Web Site
Date:  5-30-2012
Number of Hours:  2.20
Brief Description:  Fuel pressure regulator mount
Fabricated a bracket to secure the fuel pressure regulator to the airbox and carburetor. Riveted the bracket to the end of the airbox. Used a cable clamp to secure the pressure regulator fitting to the bracket. Turned a 8mm long spacer from 3/4" aluminum round stock to correctly space the regulator clamp from the bracket. Fastened the clamp to the bracket with a AN3-10A bolt.
Fuel pressure regulator bracket and clamp.
Fuel pressure regulator bracket riveted to the air box end.
