Moved the Rotec carb fuel inlet fitting to the other side to facilitate the pressure regulator mounting. Worked on fuel pressure regulator mounting method. Did the Rotec mandatory AD to provide a fuel pressure regulator reference pressure port. The reference pressure port must be connected with a hose to the air box.
