Louies Web Site
Zodiac 601XL B
Crank pos trigger wheel spacer
Finished machining the crank pos trigger wheel spacer outer diameter. It took at least 2 hours to get the spacer positioned in the lathe chuck for centering and runout. Assembled the ring gear, spacer and trigger wheel on the crankshaft.
Timing rear spacer rear
Timing ring spacer front
Saberwing Home
Zodiac 601XL B Home
4681
3250 Engine
275
334
Engine exhaust
993
Magvair Corvair
370
437
