Installed the RG 58 coax between the ELT and the ELT antenna. Put BNC connectors on each end. Began running wire between the ELT and where the ELT remote control unit will be mounted in the instrument panel. The wire cable and cable sheath had to be opened up to get the ELT control wires inside. This part of teh job isn't completed.
