Brief Description: Installed the Modified Aileron Tab on the Stick
Mounted the tab to the aileron post on the stick and then connected the lower aileron cables to the tab. Tested the linkage and found it worked ok but was a little heavy. I expect that will be the normal condition for the operation of the ailerons. One note is that the elevator cable sleeve can catch on the aileron tab under certain stick positions. This will be address before the first flight after taxi testing.
Painted each of the patches on the wings with the gray primer paint. They will need sanding during the next work day before finish painting.
