Brief Description: Start of Rivet Stitching on Top of Upper Left Wing
Turned the wing over so the top was up. Applied the 1/2 inch fiber tape to each of the ribs ensuring that the tape was centered over the stitch holes. Weather hit the airport and power was lost in the hanger. That left only operations to be done which did not require power.
Glued the fabric tape to the end rib on the wing. Glued patches over the front and rear spar ends. Glued down the wing tip tape. Glued the aileron fairing to the top of the lower left wing.
Removed the belly pan from the airplane so it can be painted.
