Brief Description: Installed the Outter Wheel Covers
Removed the right axle retaining bolt. Placed the cover on the wheel and lined up the mounting holes. Installed a 1/2 inch long 1032 screw through the cover and into the blind nut attached to the hub. Found that one of the blind nuts was a #8 and not a 10 which required the removal of the cover to replace the blind nut with the correct size. Secured the cover with five 1032 pan head screws. Repeated the process for the left cover without the need to change out any of the blind nuts.
