Brief Description: Painting Wheel Disk with Primer
Wiped down each wheel cover with acetone and let dry. Sprayed on gray self etching primer on the inside of each disk. Sprayed on a light coat horizontally followed by a second coat sprayed vertically. Left to dry. Cleaned the aft cockpit enclosure with acetone and sprayed one coat of primer. Set aside to dry. Turned over the wheel disks and cleaned and primed each top side. Cleaned the underside of the aft fuselage aluminum plate. Primed with the self etching primer and set aside to dry. Cleaned the underside of the cockpit enclosure and sprayed on one coat of primer.
