Brief Description: Instrument Panel Wiring for Alternator Light
Changed out the LED light that was installed for the alternator light and installed a 3 watt bulb. Had to enlarge the hole that the LED fit into to accept the enclosed lens. Prepared the power wire for the LED by putting a bayonet fitting on one end and a terminal on the other end. Covered both ends with a segment of white shrink tape.
