Brief Description: Installed TAC, Carb Heat, and AMP Meters
Installed the TAC, Carb Heat, and AMP instruments on the left and right sides of the instrument panel. Added the power isolation module to the AMP meter input pigtail. Used some silicone to secure the power isolation module to the back of the instrument panel. Connected the power output leads of the isolation module to the power input of the display. The leads were cut to length and a one inch segment of shrink tubing was placed over the power wire. The ends of power leads were wrapped together and soldered. Once the wire had cooled then the shrink tubing can be slid down over the splice. Repeated the connection for the ground wire for the crab air can be flowing.
