LARRY'S WEB SITE
Date:  10-31-2019
Brief Description:  Adjusted the Calipers on the Brakes
Removed the left caliper top bracket bolt and tilted the caliper back to remove the two long bolts holding the caliper to the mounting bracket. Adjusted the right side of the caliper by 1/2 turn on each of the allen nuts to close the pads closer to each other. Tested fitted the caliper back onto the stator with some effort. I wanted the fit to be a bit tight and this appears to be ok. Mounted the caliper back onto the wheel and moved to the right side and repeated the process. Completed the right side mounting. Now ready for the next taxi test.
