Completed the linkage for the left side brake peddles to the L and T brackets adjusting to align the peddles horizontally across the foot channels. Measured and constructed the two cross over linkages to fit between the brackets and adjusted the ends to align the attachment holes. All attachments were completed using AN bolts. Tested the brake peddles for correct movement at each peddle and master cylinder. Brake application was stiff at first. Applied some WD-40 to all connections in the linkage which resulted in much more smoother operation.
