Checked the movement of the controls. Decided that the turnbuckles for the elevator needed to be at the elevator and not near the stick. Removed the cables and rerouted to put the turnbuckles at the elevator horns. Also found the turn buckles connected to the rudder bar extended at a slight downward angle due to the blade connection at the rudder bar. Again rerouted the rudder cables to put the turnbuckles at the rudder horns. Used a yard stick to measure where the cables would penetrate the fabric when it is installed. Recorded the list and saved it in with the design drawings.
