Changed out the 7 1/2 amp circuit breaker for a 10 amp breaker for the scavenge pump. Tested the pump on a 30 second run without any issues.
Rolled a 1/16 inch of the inside edge of the left bezel and smoothed out with a hammer. Positioned the lens in the bezel and drilled pilot holes in the top edge for the mounting bolts. Repeated the process for the bottom three holes. Attempted to mount the lens in the opening using the top #8 screws. Trouble getting the lens to fit the opening and line up all three mounting holes. Going to borrow a dimple tool to complete the screw opening on the bezel.
