Cut away the marked area for the cockpit. Fitted the trim around the aft struts for the center wing section and marked the line for the side of the fuselage. Placed the trim in the brake and bent the edges down to fit along the fuselage. Used a vice grip with a 4 inch wide blade to bend up the edges along the cockpit. Used the expander to bend up the edges in each of the curved areas of the trim. Fitted the trim over the back of the fuselage and drilled the mounting holes.
