Brief Description: Begin Control Stick Construction
Mounted the top plate to the stick with three 3/16 inch pop rivets leaving one hole open. Turned the stick over and mounted the second plate with three 3/16 inch pop rivets. Drilled the forth hole through both plates with a 3/16 inch drill. Installed an AN3 bolt and two taps in the open hole. Slid the aileron control bracket on the control arm and positioned it per the plans.
