Brief Description: Continued Construction of Center Wing Section
Marked off on the main and aft spars one foot increments for the location of each wing rib. Attached the next completed wing rib to main spar at the marked location. Added the aft spar bracket to the wing rib and then attached it to the aft spar with two 1/8 inch pop rivets. Added the third completed wing rib at the next marked location on the main spar and completed its connection to the aft spar.
Constructed three more wing ribs using the template on the work bench. Added each of these wing ribs to the wing center section in turn securing to both the main and aft spars with 1/8 inch pop rivets. Moved the center wing section to the barn loft to continue construction.
