LARRY'S WEB SITE
Date:  4-8-2018
Brief Description:  Removed Center Wing Section for Covering
Disconnected the cross cables on the center section struts. Removed the center section and set it on the tail of the airplane. Removed the struts and cables. Marked each strut and supporting cables per the location they were removed from. Coiled the ground cables and taped them to the center frame. Set the center section aside.
Coiled the lift cables and taped them to the fuselage. Cleaned up the work area and disposed of the trash.
Center Wing Section
Center Wing Section
