Brief Description: Removed Lower Ailerons For Adding Third Hinge
I went to Aeroplanes Airdromes for hinge material for the ailerons. Also talked with Bob Baslee aboout the weight and balance for the airplane. He emailed me a speadsheet on figuring the weight and balance.
Trimmed a clearance area in the leading edge material at the drag turnbuckles. Removed the bottom ailerons in preparation of adding a third hinge to each aileron.
