Mounted the inter right wing stub rib using angle brackets on the front and rear spars. Maintained alignment with the front leading edge of the wing and the top of the last wing rib of the wing. Installed the right wing left aft corner brace using three 1/8 inch pop rivets.
Put the wood frame under the left wing and the cross bar under the upper wing to support it. Disconnected the drag cables and removed the bolts from the lower wing spars. Pulled the lower wing off of the wing stub to allow access to the end of the wing. Positioned the last wing rib and checked alignment at the end of the wing.
