Brief Description: Aileron Cabling Rigging Third Try
With the lower wing ailerons clamp to the wings completed the cable runs to each aileron horn. With the stick center measured and cut the cable to the left wing aileron horn. Installed a turnbuckle at the horn with the cable pulled tight without moving the stick. Measured and cut the cable to the right aileron horn leaving an extra six inches of slack.
