Brief Description: Left Wing Outer Sturts and Wing Alignment
Positioned the outer wing struts between the upper and lower wings next to the spars. Drilled a 3/16 inch hole through the strut and wing cross member after aligning the hole with the center of the cross member for both ends. Secured the struts to the cross member with AN3 bolts. Aligned the top ends of the struts next to the upper wing spars and drilled a 3/16 inch hole in each centered on the cross member. Secured each strut with a AN3 bolt.
Mounted the front wing spar in the front wing stub. Pulled the aft wing stub into alignment with the aft wing spar and mounted the aft spar. Aligned the left wing leading edge with the right wing leading edge and measured the wing tips to the tail post. Adjusted the wing alignment until both wing tips were an equal distant from the tail post. Drilled a 1/4 inch hole in the front and aft spars and mounted each to the respective wing stub.
