Brief Description: Fix Fuel Seep and Repositioned Left Brake Peddle
Drained the fuel tank into a gas container through the bottom drain value. Disconnected the fuel line from the fuel tank shut off value. Removed the shut off value from the fuel tank. Applied a coat of liquid gasket to the threads on the value. Inserted the value back into the fuel tank and tighten to it's vertical position. Tighten the locking nut to hold the value in place. Installed the fuel line back onto the value and tighten the collar. Returned the drained gas back into the gas tank.
Removed the left brake peddle linkage from the mounting bracket and unbolted the link to the brake peddle. Tighten the clevis on the link by 3 turns shorting the link and moving the peddle closer to the back of the cockpit. Put the bolt back into the linkage and bolted the bracket back onto the mount. Testing of the brakes will be needed during the next taxi run.
