Robert Baslee from Airdrome Aeroplanes came by and conducted a inspection on the aircraft. During the walk around the following were noted;
- Control cables must be supported to keep them off any metal that is near their route. - Corners of the ailerons and the aft wings must be braced to maintain shape. - The wing tips need additional bracing to maintain shape under covering. - The forward left bolt on the elevator requires a large washer to support the load. - Consider placing wood blocks within the bracing bolts on the vertical stabalizer. - Consider moving the outboard upright supports up next to the spars to ensure that the bolts are within 2 inches of the spar.
