Brief Description: Installed Foot Channels and Rudder Post
Mounted the two foot channels on the left side by bolting the rudder post through the channels and the frame tabs using AN3 bolts. Installed the rudder post braces and secured the aft end with an AN3 bolt through the channel and the frame tab. Added the outside bolts to each channel so all four corners were secured. Repeated the process for the right side channels.
