Brief Description: Mounting Tabs and Rudder Bar Clearance
Completed the taping of the tabs on the firewall for 1032 bolts. Checked the clearance of the stick assembly and the rudder bars. Found that there was interference with the forward pulley of the stick assembly and the rudder bar under full rudder bar deflection. Evaluating possible chances to remove the issue.
