Brief Description: Forming the Fuselage Maneuver Handle
Put a length of 1/2 inch steel tubing into the bender and positioned it for a 90 degree bend for 4 1/2 inches. Repositioned the tube 8 inches from the first bend and repeated another 90 degree bend on the same axis. Set the handle on the fuselage and marked the cutoff points. Used a chopped saw to remove the excess material from each leg. Set aside for later welding.
