Brief Description: Adding Diagonals to the Fuselage
Continued to bevel each end of the brace to fit across between each upright. Check the fitting and adjust for a close fit. Spot well in place and move to the next one. After each section is in place start welding each joint alternating between ends and sides around the fuselage.
