Brief Description: Installed Anchor Nuts in place of Clip-Nuts
This is the instrument panel. Due to the problem of keeping clip-nuts attached when putting the sheets together I decided to change the method of attachment. Replaced each clip-nut with a 1032 anchor nut. Removed each clip-nut and using a 1032 screw held the anchor nut in place to drill each anchor hole. Used a pop-rivet in each hole to anchor the nut in place. Repeated the process for all screw locations.
