Slid the left panel into place under the wing gap cover and lined up the front screw hole and test fitted the panel. Aligned the holes and installed five #1032 by 1/2 inch screws into the panel. Repeated the process for the right side panel. The test fit on the right panel did not fit correctly. The front left corner had to be trimmed to get the holes to align. It took three fitting to get the alignment correct. Installed the five #1032 by 1/2 inch screws to complete mounting the panel.
