Brief Description: Calulated Weight and Balance/ Center of Gravity
Initial calculation of weight and balance provided a CG range of 22.58 to 25.63 inches. The max gross configuration falls with in this range but the pilot only with full fuel down not. The pilot only configuration will require 30 lbs of baggage to be within limits on takeoff.
