Placed the forward cover on the fuselage. Laid both side panels in place and then set the cowling on top of the engine. Raised the tail until it was nearly level. Set up the digital scales so that one pad was available for each of the wheels. Jacked up each main wheel and slid a load cell under the tires. Placed a load cell under the tail wheel post and checked if the fuselage was level. Had to add additional 2x4's to bring the fuselage to within 0.3 degrees of level. The reading on the scale was right wheel 443 lbs., left wheel 460 lbs, and tail wheel 43 lbs with the total weight of 947 lbs. With the weights established the calculation of the center of gravity can be determined.
