Brief Description: Started Tape Up of Outter Wheel Cover Design
Marked out two triangles with 17 inch sides on butcher paper. Cut out the triangles and laid them out to form a 6 pointed star. Marked on each template the bottom of each of the points of the star. Using one of the triangles drew a line across the bottom of each of the points of the star. Marked the center of the triangle and then cut out a 1 3/4 inch circle on the center point. Laid the triangle template centered on the wheel cover and taped around each of the points. Removed the template and checked the masking tape for a firm connection to the wheel cover. The points are ready for painting during the next work day.
