LARRY'S WEB SITE
Date:  5-17-2018
Number of Hours:  2.50
Brief Description:  Fixing the Interfacing Between the Center and Righ
Set the center wing section on the work table. Secured with pop rivets a 4 inch section of 1 inch angle to the brackets on the end ribs for reinforcement. Brought the right wing to the table and mated it to the center wing. Adjusted the spar spacing to match and slid the wings together. Adjusted the leading edge on the center wing to match the leading edge of the right wing. Adjusted the center wing rib next to the right wing rib to match its profile. Bent the leading edge top down about 25 degrees on the center wing section.
Removed the right wing and put it back on the rack. Took the left wing and mated it up with the center section. Adjusted the leading edge of the left wing to match the center section. Started on the end rib of the left wing to match the profile of the center wing. Ran out of day so that is left for the next work day.
Center and Right Wing Interface
