Beyond Blue
Cozy MKIV
Chap 3 : Training
6-12-2010
Chapter 3
3rd Layup Preparation
The 1 inch foam block was removed from the base with a butcher knife and sanding block.
The edges from the second layup were sanded. The bottom glass surface was sanded dull.
A 1/4 inch flox corner was marked then the foam removed using a precision knife.
The tools, work table, and shop floor were cleaned and the base is ready for the 3rd and final layup of this practice piece.
Remove 1" foam block & sand
Mark 1/4" flox corner
Remove foam for flox corner
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
