Brief Description: Prepare Fuselage Bottom for Glassing
Preparing the fuselage bottom for glassing ....
The Dremel tool was used to remove foam around the edge of the NACA scoop in preparation for creating flox corners.
The top edges of the NACA scoop were sanded.
The edges of the F22, Firewall, and Landing Gear bulkheads were rounded to accommodate where the glass cloth will roll over the edges onto the bulkheads.
36 Grit sandpaper was used on the firewall and landing gear bulkheads.
the fuselage bottom, sides, and bulkheads were vacuumed.
Two 30 degree fiber orientation lines were drawn on the bottom of the fuselage for reference during glassing.
