Beyond Blue
Cozy MKIV
Step 1
Install Aluminum Inserts
Radius the corners around the joggle so that the BID cloth will better fit into the joggles.
Workshop temperature 24 deg C and humidity 51%.
A small batch of flox was mixed using 32g resin and 12g hardner.
Flox was placed inside each aluminum insert location and the inserts were installed flush with the landing gear bulkheads.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
